Lenovo RX 6800 XT clocks to use less W and less temp
I have Gigabyte and Lenovo RX 6800 XT
Help please with clock on Lenovo RX 6800 XT to use less power (W) and to lower Mem Temp.
Gigabyte clocks do not work (card crashes).
find the lowest clocks//voltages that are stable. if its not stable, raise voltages
Where do I start?
start high and go down or start low and go up
hello, there are no 100% perfect parameters for each card, you have to try to make small adjustments one at a time, I show you my parameters for 6 rx 6800 xt cards, if you look closely I have one that consumes about 110w and I can not lower more, but for me it is perfect 99.9 efficiency for the 6 cards.
I usually make my frequency adjustments like this, I adjust up or down in 2 MHZ steps.
I adjust the voltages up or down in 5mV steps.
Preferably you have to stop miner before each setting and then restart it.
setting Soc VDDmax is very important to achieve low power consumption
I use Phoenixminer
What miner are you using?
Do you leave intensity on auto or set a predefined value?
gminer v2.78
i dont know anything about intensity :frowning:
what would be the parameters for me to start from?
i mean maximum, that will not crash and then i start lowering?
