L3+ boards not detected cannot fix with Hiveos installed please help
I have recently downloaded hiveos and like the firmware but cannot re write my hashing boards with it installed. I try to run the “fix” and I get cannot find signature . I have tried removing hiveos and same problem even tried with sd card and stock firmware and no luck. How can I re write or fix my hashing boards while hive is installed? Or how can I remove hiveos in order to run the fix for my L3+ hashing boards? Any help would be very appreciated.
Put Hive ASIC image on a SD card, then put that SD card into your L3+.
https://download.hiveos.farm/asic/L3%2B/SD-L3%2B-Hiveon-latest.zip
ASIC FIRMWARE: How to flash via SD Card (HiveOn by HiveOs) upgrade software (cannot find signature) - YouTube
Yes I have tried using the SD card and still no luck. I still cannot run the board detection fix. It is still saying cannot find signature.
