Keep Disconnecting As of a Few Days Ago
I haven’t changed anything with my PC before this started happening. I also did the selfupgrade command today. When my PC starts it shows bad gateway but the miner screen does run. However, it disconnects after 15 minutes. When restarting it disconnects quickly with some text on white message about closed by pool before the PC restarts. I even went online to turn off the watchdog.
[Not allowed] any feedback.
Run net-test while youre having api issues, and then with the info from that test, set your api in the workers settings to the one with the best connection and reboot. Repeat until not needed.
