Kaspa (KAS) and RX 5700 on srb miner. Strange problems
Can someone explain this? 4 gpu mining and 4 not, see the picture.
I have (–disable-cpu) mining, cpu temp is now 30 degrees, not as in the picture. But it didn’t help
Seems to be an issue with that miner and some 5700s. You can use bzminer on the problem cards and get around 180mh. They’re not great on kaspa either way though
use lolminer, to mine ETC at 50(5700) and 53(5700XT) with kaspa at the same time.
