Keaton, thanks for the feedback but the locked core clock doesn’t seem to be working for the 2080ti - you can see gpu1 is stuck at a core of 825, which is not coming from the flight sheet nor my manual adjustments in hive.
It’s being throttled by your power limit.
Can you give more details of your setup? Did you make adjustments to the miner like cclk or mclk?
810 memory is an offset rather than an absolute clock. Try using -3000 to lock the memory to 810
you put lolmeiner and the clock straight miner for 3070 are
–coff 255 --cclk 1470 --mclk 810 --pl 100
