Issues with ASRock H110 Pro BTC+ HiveOS Installation
Hello everyone, I was wondering if anyone could help me troubleshoot an issue. I’ve put together a rig and installed windows, and have flashed HiveOS just like all of the instructions, but when I put it into a rig I cannot get it to boot from BIOS to get HiveOS. Every time I adjust the BIOS and attempt to get it to boot, it just hits a blank screen. I was wondering what BIOS setting people used with the ASRock H110 Pro BTC+ . Thank you so much.
I’m using the same board and didn’t have any issues at all. My BIOS settings are default. Which USB port did you insert Hive OS? I placed mine on one of the ports near the DVI. Placing it in the USB 3 port didn’t work for me.
Thank you that worked! Also, I didn’t have my Molex cables attached to the MOBO, and after those were put in it booted. Thank you!
