I’m hoping someone can help me. I’ve just setup a Hive OS rig that currently has 2 cards - an ASUS ROG Strig RX 5700 XT and an EVGA RTX 3070. I have no issues with the 3070, that works really well. The issue comes with the 5700 xt.
When I load up the card without any changes it works fine. I can even mod the core, VDD/VDDCI/MVDD without issues. However, when I apply any value to the memory clock the card fails. The other issue is that if I don’t apply a fan value then the fan will stay at about 25% and the card will over heat.
I haven’t bios modded the card at all.
I’ve been running this card on windows without issue with the following values:
Core clock: 1350
Voltage: 800
Mem: 1800
My current settings are for this card are:
Core: 1350
VVD/VDDCI/MVDD: 775/775/1300
Please note that if memory is the only value I change the card will crash. If other settings are changed and I change the memory, the card will crash.
Running on Hive OS 0.6-200@210302
OpenCL 20.40
I’m getting 50.63 MH at 101W, so I’m only losing ~1 - 2 MH from what I was on windows with the current settings, but it’d be good to figure out why I can’t change it and see if I can get more out of the card.
Any help would be greatly appreciated.
