very strange dude, if you are ok with windows , mine with it.
I hava same issue With H510. Only 1 gpu working. From widows all 6 gpus working fine but i like hiveos.
Hope that issue will receive a fix.
Any updates to make the work with multiple GPUs and running HiveOS?
Maybe this helps?
He said to change the PCIe slots to Gen1…
Hi, I had the same problem, but I entered the BIOS, I changed the GEN on each slot and it works Normally (System Hiveios) to GEN 1 did not work until after setting the GEN2 it started working
Sorry, important Information you can Try before Combinations with BIOSE set Card Overclock to 0 without Power, of course then It should catch after Firing Wait a little and Only Combine with Overclock when it reboots and it will be a problem set Card Overclock to 0
