Hi there
I have a small miner with 4 GPUS on a BIOSTAR TB250 running Hive Os.
The miner is really loud mostly because of the Fans that I install in front of the GPUs. Is there any way to lower the RPM of the case fans?
If yes how and what are the value I should put.
thank you Filippo
