Is there a way to auto reboot rig based on accepted share ratio/invalid shares?
Is there a way to set up the watch dog in hiveos or a miner to reboot the rig when the accepted share ratio is below a certain percent or count?
Would like to know as well.
I would like to second this one!
count me in
for example:
reboot if accepted shares < 97%
would be lovely
You most probably could do that with help of the Hive API. However, that requires that you then code the logic and utilise the API to read the information on share ratio and rebooting. One way to do it is as a Linux shell script and running by cron.
