It’s been like this for a couple of hours. what is the problem
are there gaps on your pools graphs too? if so your rig is going down, if not its just a visual api server glitch.
thank you for the answer
Same issue! I’m away from home right now but I noticed that there’ve been some cuts and now it says “offline”. Was wondering if it’s Hiveos or me because my internet is online at home.
Edit: It seems that my LAN switch was having a fun time on its own xD I plugged off the power cable, then plugged back in, voilà. BUT, I think I’ve just observed some connectivity issues with the API, it might explain the gaps in the data.
