Installing a wireless USB adapter on an Octominer?
Hi all, new here. Please refile if necessary!
I am running HiveOS on an octominer, currently using a wired ethernet connection. I would like to install a TP link Wireless N Nano USB Adapter (TL-WN725N). Curious if it is possible to do the install through the OS? What’s the easiest solution?
should be able to just plug it in and run wifi to configure, or set your ssid/password in wifi.txt in the network folder on the root of the drive
