Immersion cooling rig
Cooling with engineering fluids. Not very efficiency because I need extra water pump and fan and the fluids. This rig is more like fun.
Only problem is the 3090 overheating. This rig is indoor now, plan to move it outside.
Seems like more power, more trouble and warmer temps than just regular stock coolers. Hopefully it’s at least quieter?
Yes more power from the water pump, the radiator fan stays at low speed. no fan on gpu. So basically the noise comes from the pump. The temperature is relatively low except for 3090. My room temperature is set to stay at 70F and the liquid is basically kept at 105f, still very low for VRAM.
