I need a display to start Hiveos ! Why?
My hiveos doesn’t work if i don’t connect a display.
Mobo: MSI b450 gaming plus max
GPU: Asus tuf 3060 ti (just 1)
After connecting my rig to the TV with an HDMI cable, my rig goes online on Hiveos web page when I power my rig up. After Hiveos is running, there is no problem if I unplug the cable.
But I boot my rig without a display connection, My rig offline on Hiveos web page and I can’t run hiveos shell or shellinbox.
Why? Could you please help me?
I have a mix of rigs, only one motherboard in particular is touchy about an external monitor connection and it is a known motherboard issue. All my other Rigs are headless.
I’d look at the BIOS&Motherboard for limitations first.
Same motherboard, same GPU, same problem.
Did you find a solution for the problem?
