About 2 days ago i built a rig and it worked really good from the start. I made flight sheets with different coins and different overclocks. And then, yesterday. I decided to update to the newest hiveOS version as well as updating the BIOS on the mobo. After that, i added 2 more cards (2x 2060’s) to the rig and then fired it up. Everything seemed fine. I made some overclocks to it and changed the flight sheet a bit. After i was comfortable with the overclocks i let the rig mine for a while. After about an hour i came back and the rig was offline. I checked the monitor on the rig itself and the screen was frozen. I thought it was weird but i rebooted on the mobo powerbutton. After rebooting it i decided to sit there and monitor the rig to see if the problem would occur again. And it did. I rebooted it many times with the same problem every time. I tried changing overclocks, flight sheets and tried checking logs (although i dont know what im looking for in the logs or if it even says anything useful). After a few hours of this going back and forth with the same results, i went to bed for the day.
Next day i tried some new things. I reflashed the bios to the version the mobo came with as well as completely reinstalling hiveOS. This did not work. I even removed the 2 gpus and risers that i added before these problems started. That did not work either. I do not know what more to do.
This is what i have gathered these last 2 days:
The freezes look like the monitor has frozen in time since the freeze. And it requires me to hold the power button and make it restart.
The freezes usually happen after about 20 minutes of mining since reboot.
it might be some kind of hardware problem or software problem, i dont know though. Maybe mobo? Gpu? Risers? (although the risers did work perfectly the first day) cpu? Overclocks? Miners?
Specs of rig:
4GB of ram
asrock h110 pro btc+
intel core i5-6400T 2.20GHz
iomega HDD usb drive
Here is a picture of the gpus and their overclocks:
The gpus are all mining different coins and using different miners.
On the rx6800 and 6800xt i am mining ethereum with TeamRedMiner
The 2060’s are mining RVN (kawpow) on nbminer
The 2 3060’s are also mining RVN (kawpow) on nbminer
The 3070ti is mining ERGO (autolykos2) on lolminer.
The 1660 super is mining Ethereum on t-rex miner
I am out of options on what to do. Please help me
I am considering trying to install windows just to see if it can mine longer than 20 minutes without freezing.
