Is there a miner start command that allows you to select which GPUs to mine on? I’m trying to measure the various cards power consumption. Is there a switch that I can add to miner start to specify to mine only on GPU 3 for example?
There are settings for the m8ner to tell it which gpu to use for miner. Read the miner parameter settings manual and find the proper parameter.
