How to mine to deferent coins on same rig
How to start rest 5 gpu to mine Zencash. What im doing wrong here? Wallet is my username on supernova
Use forum search for “Second miner” feature
Also quick info from HiveOS author
What if I need more than two miners? I have real case, where I use 4 different miners (3 copies of Claymore for different graphic cards and 1 other miner for CPU). For example, new Claymore don’t take devfee for cards winth 2gb RAM. But if I have different cards with 2 gb and 4gb RAM and start one copy of claymore for all cards, devfee will be for all cards. If I run two copies of Claymore, one of them (where 2 GB cards) will not take the devfee.
Current version of HiveOS support run simultaneously only TWO DIFFERENT miners. You can run other copies but you must run it manually without any web-stats and web-control.
AFAIK feature you are asking about is scheduled in HiveOS 2.0.
Do you mean, than I can’t run even 2 copies of the same Claymore? It should be completely different progams?
