Hello. This is the first time I’m having trouble with flightsheep. I started making a kit on lhr cards. No lhr kits did not have this problem. Does anyone know how to help? On my other sets but not lhr I didn’t have this problem Thanks for help
Typically either an unstable connection or a corrupted install will cause this. Do you have another drive to test with?
This is a new disk straight from the store, I do not think it is a disk, tomorrow I will see another one. But if since the disk is reading the graphic card, can it be broken just In fighter sleep? and what do you mean with unstable connection, where to look for it? Thanks for answer, and help.
Did you try reflashing the drive? You can run net-test from shell and see if there’s any connection issues.
