Hi, i made some modification and now Nemosminer can work with Hive
follow instructions from README.md
fell free to ask any questions here
Now we are talking
THANK YOU!!!
Some extra instructions:
Open Git Bash
Connect to your HiveOS Miner. Enter: ssh [email protected]
Create your RSA key: ssh-keygen -t rsa -b 4096 -C "[email protected]"
Ensure the ssh-agent is running: eval $(ssh-agent -s)
Add key to agent: ssh-add ~/.ssh/id_rsa
Now you need to copy the SSA key from your miner to windows
Go back to your Git logged into your windows system
Copy the SSH: ssh-copy-id [email protected]
This should save the key in place and allow you to login with Public Key.
is there a newbie guide for this? o:)
+1
@thexravenx i already follow your clue ,after step 22 we need start the .bat in windows right ? its already can connect to hive but after stop miner its start again miner but cant switch algo ,and miner config its my old config in hive before ,please help…
thanks
[quote=“milekz;329”]Hi, i made some modification and now Nemosminer can work with Hive
fell free to ask any questions here [/quote]
hi ,can you tell me how to setup details,its already can connect to hive but after stop miner its start again miner but cant switch algo ,and miner config its my old config in hive before ,please help…
is there a dummies guide?
Unfortunately I could not find one, but I can confirm that I have set it up and it is running. It can auto change algos and miners (ccminer forks) but has some issues.
One main problem for me is not related directly to nemosminer but It affects me because I cannot mine with it long time.
Because the system (HiveOSrig) restarts, not been able to set custom OC for different algos, the rig gets a new IP from the OpenVpn server and then nemosminer cannot find it again and I have to manualy edit the files in order to change to the new IP.
I need to have OpenVPN static IP for my rig-client, or any other solution proposals?
I would like to use it a lot but we need some help from the devs.
Thank you for the guide
I have set up everything like in the guide, what do i do now?
Do I run the bat file on my windows machine?
How do i configure hiveos? What ccminer fork do i choose, what algo in the wallet prole etc etc?
My CCminer in hiveOS is just mining but it doesnt seem to be switching or sending stats to my windows machine
