Hello. I was successfully mining on Hive OS using wifi adapter. All I had to do was just connect the adapter in USB and type SSID and password and it worked.
Now I got a myself a broadband connection but it doesn’t connect. I connect the ethernet cable, it lights up but no internet on HIVE OS. Internet is working on modem but not on HIVE OS. Please tell me how do I set it up. I don’t know much about linux.
Problem solved. After a few restarts. Now it is running.
Hi, anyone know how to connect over SSH ?
what a username & password must i use ?
Please advice! After the light in house was off, made restart of farm,but no connection though
please advice!
i have the same issue but even after restarting numerous times it still isn’t working how many times did u restart or is there a other solution
