How to auto reboot when fan reach X percent speed?
I want to auto-reboot when fan reach 85% speed but found no option to do so. Any idea how?
This is to workaround an issue of
  • After the system is running for a while (never consistent, but usually after more than 1-day uptime), the GPU will be getting hotter and hotter, thus the fan speed reaching almost 100%.
If i reboot, it will work fine again, the GPU will be 65c at ~50% fan speed. But this wont last, as after running for awhile it will have the GPU getting hotter and hotter again.
