This is hivos power consumption and hashrate
GeForce RTX 2060 5934 MB · GALAX
Micron GDDR6 · 90.06.3C.00.18 · PL 125 W, 160 W, 160 W
but in windows os NICSHASH i can reduce the power consumption to 74W with 30MH hashrat
no this is not the power consumption. whats the OC settings you are using? put a picture of the OCs and the results you get.
Nvidia settings applied with errors 3m 15s
=== GPU 2, 04:00.0 GeForce RTX 2060 5934 MB, PL: 125 W, 160 W, 160 W === 17:16:04
SET CLOCKS: 0 MHz
INVALID POWER LIMIT 90.0 W, MIN: 125.0 W, MAX: 160.0 W
(exitcode=2)
Max Perf mode: 4 (auto)
Attribute ‘GPUMemoryTransferRateOffset’ was already set to 800
Attribute ‘GPUFanControlState’ (hive1200W:0[gpu:2]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (hive1200W:0[fan:2]) assigned value 65.
Attribute ‘GPUGraphicsClockOffset’ (hive1200W:0[gpu:2]) assigned value
-765.
every time i set oc setting under 125W is failuer
use absolute core clock as what zajcew said above.
thanks it worked
