Hot temps and system reboots
some of the cards on my system are getting really hot… Also the system reboots every 15 or 20 minutes, maybe due to the hot temps?
How can I lowers the temps on my 2060 supers?
thanks
Wrong oc settings…for 2060 supers
Try Core 1100 mem 1800
For 2070
Try Core -50 mem 2000
For 1660 super
Try Core 1100 mem 1700
hi,
with your settings the unstability seems solved and most of the cards tempuratures are OK, except 1… I put it apart so won’t get hot air from others, but still at 77º
thanks for the OCs
Lower your mem mhz in that (1700???) and core 1050 (this card throttling !!! from temps) also put 90% value on all fan’s…
You have very high temps on core and mem …
Remove PL … to see what is the real consumption and put it after…
Also is good idea to restart your rig after OC fixes…
