good I need help with my rig, I have a CPU processor
12 × AMD Ryzen 5 5600G with Radeon Graphics AES and the hiveos does not read the temperature and in the bios if the temperature of the cpu is seen I am with the latest version, does anyone know what it can be, thanks
it doesnt show the temp at the bottom of your worker overview screen?
No
exactly that is problem
disable the integrated graphics in the bios
I already did it and if I deactivate them the motherboard does not boot and turns on the CSM then the hiveos does not see all the cards only 2, that’s why I leave the integrated card activated so that the hiveos sees all the cards, but equally if I leave only one card and I boot hiveos with only one with the integrated card disabled the temperature is not seen
you should be able to disable the integrated graphics and keep csm off
I have the same issue with Ryzen 7 5700G.
Somebody know how to fix this issue?
