Hi All,
So I’m trying to set up my first rig on Hive, I have a few small rigs running on windows. I’ve tried creating a boot drive on a USB stick and SSD using both the beta and stable version. Pc posts and I can select Hive but then it seems to get stuck on the screen I have posted a photo of. Can’t figure out the problem.
It is an old motherboard, having a hard time finding boards. Asus Z77 gen 1 i7, not sure if it might be a compatibility problem, or that there is no onboard display (grabbing for straws possibly)
Any Help will be greatly appreciated
Regards
Dj
If it’s an older MoBo, is it compatible with the drivers for your GPUs?
