hey hi everyone, i just started can anyone suggest me better settings?
you want to fine tune each card. dont use core offsets ( the -500) hive treats values above 500 in the core field as locked.
- remove all oc
- find highest stable mem clock per card. if it crashes, lower and reboot. this will be different for each card
- find lowest locked core clock that maintains full hashrate for each card.
no need for power limits with fine tuned core clocks.
I can’t lower the memory temperature of the asus tuf rtx 3070 ti no matter what settings I try, does anyone have any suggestions for this?
Aside from lowering the memory clock which will lower your hashrate, you either need to increase airflow (add a fan, open a window etc) or replace the thermal pads upgraded ones
