HIVE OS not flashing GPU's or downloading VBIOS
which card you are trying to download the bios.
Thanks. All is good. The VBIOS did not need to be flashed but I changed the miner SW and all works fine now.
This topic can be closed now.
Hello guys, I found 100% solution to this problem . This problem occurs, if you have both rx 580 and AMD 5700,6600 or other XT AMD cards. so shutdown your rig disconnect these cards from motherboard and leave only rx 580 cards, I hope this helps ^^
