Great job. I can only imagine how much work is behind all this.
After few hours of testing, here are several things I found not as I would expect them to be:
In Overview, clicking on “Online”, “Offline”, “With Errors” is not doing anything for me. No filtering… all the time list is displaying all of my rigs. On the other hand - nice feature to filter based on wallets, miners, cards, …
If I understood corectly, current wallet is divided into wallet and flight sheet (ex miner section). My flight sheet for dual-thread mining on xmr-stack is not copied. So, after migrating to Hive2 my rig is still working, but after editing wallet and flight sheet - it stopped. I had to reconfigure dual-thread config for my cards in flight sheet. If you are not going to copy those configurations from existing wallets to new flight sheets - this should be announced prior to migration since I find it a major hold-up…
Worker overview of dual-threaded mining. It isn’t good in current Hive, and it isn’t any better in the new one. I have 13-card rig and on worker overview, there are 26 squares with temps and hash speed (as if I have 26 cards) but only first 13 sqares are displaying fan speed (percentage). As in current Hive, extra threads per GPU are displayed as CPUs. And if you configure real CPU mining on those rigs - there is a mess in numbers… Maybe, a bit more work on presentation of multi-threaded mining would be beneficial.
I am still unable to find a way how to apply different wallet to the rig. Clicking on a Rocket allows for Filght Sheet change… can’t find how to change wallet?!? Must be me, but stil… So, how do I apply different wallet to existing rig?
I found the info on number of rigs per different Flight sheet. Can’t find same info for the wallets.
Overview page is showing hash rate per coin and per algo… A bit redundant for my taste. in example, there are so many flavours of CryptoNight algo - don’t think that you will be showing each flavour respectively.
This thing with mandatory selection of coins per wallet. If I am mining algo on MPH, Nicehash, … I am not mining any coin specifically. So, maybe, you can allow for a Custom description there (pool name or something). I beleive this is only a “label thing” so I can choose any coin I like, but still…
OC Profiles - pretty sure I have few of those as well on current Hive, but none has been copied. Simillar as with wallets - can’t find a way to apply different OC profile to a rig
Flight sheet - after applying huge config for dual-threaded mining, this list becomes very unreadable… and I am using my laptop. What if I try to use mobile phone?!? Displaying a list should limit the size of each field to only few letters…
This is from me so far…
Rgds
