Hi guys,
I have a problem with a new installed rig I bought recently. My GPUs are RX 580 8GB, I have set the all setting according to other miners on internet. The problem is that Hive OS doesn’t show me any etahash. It also show “high load average problem”, and sometimes “low hashrate” and some times “offline”. I don’t know what to do. It got me crazy!
I have attached some photo from my hive os account. Plz help!
Maybe your Memory or CPU ?
How can I check?
Thanks, the problem solved, it was Bios setting problem of my GPUs. It was using my CPU 99%
Hello, would you please explain how you solve it
