Good day fellow miners,
I have added a rx570 to my existing rig which have 3x rx560’s.
The problem is that the rx570 fan is running 60%.
The fans of the 3x rx560s is at 22%
How can I bring down the fan speed of the rx570 ?
Thank you.
Thank you.
Check FAN settings … looks like there is value 60
and can You give more info like print-screen where is settings and OS version…
[quote=“raito88;4643”]Check FAN settings … looks like there is value 60
and can You give more info like print-screen where is settings and OS version…[/quote]
PS.
HiveOS shows the rx560’s as 460’s ?
Perhaps its normal for the rx570 fan to be at 60% ? Although the rx560 fans are all at 22%
A 570 at reported 120W seems a lot. Try to change OC value (I see that you put 1100/1850 for every card, no undervolt value). Fans at 60% is not a problem really (in fact, I have few cards that are always over 70%, at 70degres). What kidn of rig do you have? Open air?
Thank you for the reply.
Which undervolt setting would you suggest ?
Its a open air frame and its currenly winter here.
What should be the fan speed on a RX480 8GB?
Thank you
