I am new to the mining world. I have 2 rigs with 6 cards (RTX 3060) each. Each card consumes 110 watts, but overall one rig consumes 1.2kW, and 2 rigs consume 2.4 kW. Additionally, I am having a high accept/reject ratio. Can please someone guide me through this problem?!
are you cpu mining as well? what power supply efficiency? what miner are you using?
Do you have your cpu voltage as low as it will go?
How can I check that?
You may not be able to set custom voltages for your cpu model, if youβre paying for electricity itβs likely not profitable either btw. It would be in the bios though
Access the HiveOs settings for that worker and find this section. This will impact what shows up as power consumption
Thank you very much. It has changed. Much respect!
