Help with a 3070 only giving 30MH/s
I just got my first 3070. It’s a gainward phantom.
Updated my rig to lastest HiveOS, and latest nvidea drivers
5.4.80-hiveos · H 0.6-210 · N 470.74 · up 6 minutes 24 seconds
Miner · ID XXX · LA 0.34 0.20 0.09 · RAM 3.8G available 2.6G (68%)
sda4 total 15G used 4.7G free 9.4G (66%) · TOSHIBA TransMemory 14.5G
eth0 routable ip 192.168.1.38 gw 192.168.1.1 dns 8.8.8.8 8.8.4.4 · alx
0 01:00.0 GeForce GTX 1070 8119 MB (86.04.50.40.0A) 58°C 53 % 99 W
1 02:00.0 GeForce RTX 3070 7982 MB (94.04.46.00.D1) 38°C 30 % 124 W
2 05:00.0 GeForce GTX 1070 8119 MB (86.04.50.40.4A) 56°C 39 % 101 W
Flightsheet: “Nano T rex” · t-rex 0.23.1
If I leave default values on my 3070 I get around 27 MH/s.
Using many different settings I found in the forum I manage to go up to 33 MH/s, but this card is suposed to get me up to 60 MH/s
Right now using CORE -600 MEM 2800 PL 125 I get 33 MH/s which is the ax I’ve gotten out of it.
Here’s info about the card
=== GPU 1, 02:00.0 GeForce RTX 3070 7982 MB ===
Bios 94.04.46.00.D1, PCIE Link Gen 3, PCIE Link Width 1x
S/N -, UUID GPU-388d95ba-9480-5d11-2137-ca31f0684499
Power Limit: Min 100.0 W, Default 290.0 W, Max 330.0 W, Current 125.0 W
Frequency: GFXCore 1245 MHz, MEMCore 8200 MHz
Memory: Total 7982 MB, Used 4731 MB, Free 3250 MB, Samsung GDDR6
Utilization: GPU 100 %, MEM 65 %
PSTATE P2, PWR 124.6 W, Temp 38 °C, Fan 30 %, RPM 1299 (30 %), RPM 1304 (30 %)
As said I have tried many configurations with similar results. None going higher than 33 MH/s.
I have tried different ports on the motherboard
I have tried turning off all the other cards and leaving just the 3070
I have tried with different power cables
I have search for this specific card on the internet, and I don’t find anything in particular that’s wrong with the card.
This card is LHR, but if I understand correctly with nvidia 470 driver it shouldn’t be an issue, right?
Anyone has any idea what could be wrong?
For documentation sake. LHR card are not completely unlock at this point Sep 2021, but gminer higher than v2.6 can unlock around 70% of the mining power for ETH and other coins.
