Help with 3070 TI configs
Hey, guys im new to mining. Saw some people getting over 52mh/s with 3070 ti cards. Can you tell my why my zotac and gigabyte 3070 ti only getting >47 mh/s.
Thanks.
I think the major problem is the use of power limit which is unconsistent when using absolute core clock.
Overclock
Try to set core clock at 1350, remove power limit and consider not EVERY 3070 ti can run stable at +2600 mem clock, personally i use it at +2200 because of silicon lottery, so try to start at +2400 and look at the hashrate you get.
T-Rex settings
There is an other smart thing to do for improve hashrate and hit the best for each card:
Use t-rex extra parameters:
dont’ copy the orange description.
Here the parameters:
"lhr-autotune-step-size":"0.1"
"lhr-autotune-interval":"5"
"lhr-tune":"74.5,0"
this helped me alot! Thanks!
