I am using HiveOS [email protected] Current running off a SanDisk 64GB USB with five Nvidia RTX 2070 Supers.
I have kept it up to date with the incremental updates from the browser UI but when I tried to setup a Flightsheet using lolminer or NBMiner I kept getting the error ./nbminer: /lib/x86_64-linux-gnu/libc.so.6: ‘GLIBC_2.25’ not found (required by ./nbminer) or lolminer if using that
After a bit of searching it seems that the dependencies or whatever get borked with incremental updates so I tried to do a full update using “hive-replace -s -y” and I get the error message "E: Package ‘fdisk’ has no installation candidate Failed to install required packages" and it boots me out of the hive-replace wizard.
So my question is does anybody know how to unscrew either lolminer, nbminer, or the hive-replace function?
EDIT: Forgot to mention that I already tried the tier 1 tricks of using “sudo apt-get update”, “sudo apt-get upgrade -y”, and updated the Nvidia GPU drivers to version 510.73.05
