does the card work on its own? if everything works individually and only doesnt work when you have 6 cards its likely a bios setting issue assuming your motherboard is capable of 6 cards.
thanks for the reply. the plate if it works alone. the issue is when I add it to the rig I get the image. the mother is a gigabyte GA-Z270X-Gaming 7.
look for everything in the bios. the only thing I could find was to put pcie in 2 generation. something else that can change.
