Help please. No CUDA-capable device is detected rx 5700 xt challenger
I have this error
unable to enum CUDA GPUs: no CUDA-capable device is detected
OpenCL driver version: 19.20
No available GPUs for mining. Please check your drivers and/or hardware
MBoard zotacb150
card asrock 5700xt challenger
any help please?
You need Beta version (for RX 5700 XT need v19.30 AMD OpenCL driver, you had 19.20)
Where do i get that one?
thanks¡
You can update existing installation via Remote Access / Hive Shell
type command
hive-replace -y --beta
or you can download Beta image from here https://hiveos.farm/install/
thanks again¡
it is already working¡¡¡
now i need to lowdown de memory temperature. is red in 90-92 degrees
how can i doo that?
Use autofan feature and set target memory temperature
great¡ i Did and worked¡
thanks ¡ you are the most ¡
i have the same problem but with rtx 3070. is there any fix plz.
Unable to enum cuda gpus:no cuda-capable device is detected
Opencl driver version:20.40-1147287
no available pus for mining.
Phonenixminer
