i have problem , my vga card stuck at 28.8mh/s default setting , i try set famous setting in hiveos then blank and load average in hiveos is coloured red after this reboot that rig , if you use the default miner, it will run stable, can anyone help ?
You have to find the min voltages and max memory that gets you max hashrate, it’s trial and error
is there any recommendation? ,I tried the core clock 1100 and the memory clock 1150 after that it immediately crashed
i follow your settings is crash
i try settings core 1050 vdd 670 memory clock 1050 up to 30.27mh/s ,if I increase the memory clock it will crash
