I was running my OS off a USB stick fine and the wifi was working. I installed it to my SSD and setup again but now the WIFI adaptor isn’t working.
I followed the first time Having problems seeing my wifi Ubuntu Gnome 16.04 and it worked but since installing onto the SSD and doing the same its not working.
No wlan0 interface found
Please check drivers, try lsusb to check USB device is present
[email protected]:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0bda:0811 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
On the working device
[email protected]:~# dkms status
amdgpu, 18.10-572953, 4.13.16-hiveos, x86_64: installed
amdgpu, 18.10-572953, 4.4.0-127-generic, x86_64: installed
nvidia, 390.59, 4.13.16-hiveos, x86_64: installed
nvidia, 390.59, 4.4.0-127-generic, x86_64: installed
rtl8812au, 4.2.2, 4.13.16-hiveos, x86_64: installed
rtl8812au, 4.2.2, 4.4.0-127-generic, x86_64: installed
On the SSD
rtl8812au, 4.2.2, 4.13.16-hiveos, x86_64: installed (WARNING! Diff between built and installed module!)
rtl8812au, 4.3.8.12175.20140902+dfsg: added
rtl8812au, 5.2.9: added
Ive also tried
sudo apt purge rtl8812au-dkms
sudo apt install git
git clone https://github.com/gnab/rtl8812au.git
sudo cp -r rtl8812au /usr/src/rtl8812au-4.2.2
sudo dkms add -m rtl8812au -v 4.2.2
sudo dkms build -m rtl8812au -v 4.2.2
sudo dkms install -m rtl8812au -v 4.2.2
Any advise? I think from trying to fix it ive been making it worse.
