Hello, I would like to mine Ravencoin.
I have 4 x 3060 ti, 1 x 3070, and 1 x 5700 xt
when I mine in ETH it works great but when I switch into Raven nothing happens.
I wonder if someone can help me in how to create my flight sheet and how to configure my cards cause it seems that energy consumption it is higher when I go in whattomine
Thanks for your help
Hey mate
I’m new to mining but not to overclocking
I’ve worked out you can’t run the same overclocks for different coins (algs)
I’d say that’s why you can save OC templates to different algs
Clear all OC re-boot
Start mining stock first to check all’s working well then start your overclocking again based on what the RVN alg likes
