So I accidently deleted my hive account… I thought i was deleting a farm i was no longer using. Turns out it was my entire account!!!
How do I get my workers back?
Any help would be very appreciated.
Big tip! don’t delete your account hahaha. There is no way to get your workers back once you account is deleted. You have to start again…
Here’s the answer. run/type firstrun -f in hive command line interference . (as your worker will continue to do whatever it was doing before the DELETE hah) this will take you back to entering a new id and password
Hopefully that helps some other silly noob like me hahah
Thanks for sharing the fix. Glad you found your way out of the hole
