[HELP] How to set 3070ti mines eth(only) and 3060 mines eth+rvn(dual) on a flightsheet?
I wanna to mine eth with 3070ti(GPU#0) and 3060(GPU#1) mining on eth+rvn,
At the beginning, I create two T-rex miner in one same flight sheet, and HIVEOS said it’s not illegal.
so i create two flight sheets , one for eth and the other for eth+rvn.
But it seems that only one flight sheet being activated at one time?
Then I tried the setting as following
Here is my setting :
Extra config arguments:
“worker”: “%WORKER_NAME%”
“coin”: “%COIN%”
“lhr-tune” : “72,30”
“lhr-autotune-mode” : “off”
“lhr-algo”: “kawpow”
“url2”: “stratum-ravencoin.flypool.org:3333”
“user2”: “RDzhPXiK1kDqPD5FXu3kKY3FieU3cariLz.rig0”
“pass2”: “x”
How to make 3070ti mine eth only?
Thank you.
You create 1 flight sheet but add two miners. Towards the bottom left of the flight sheet, there is an add miner button.
You cannot add the same miner to a flight sheet more than once. so i recommend t-rex for the dual mining, then pick nbminer or lol for the 3070ti on ETH only
