Hi
I did try to remember what i did before setting up eth
but all gone …
im looking to move to rvn , best time to move ?
i have funds will i lose funds if i move to another or should i wait
i did read windows install but realised im on L lol so back to sqr1
any help please
thanks
more gpu cards being added soon
<<<<< seems im mini now strange a minime lol oh dear >>>>>>
LOL
Who is this guy opps
should i delete mini and stick with my first choice hashtoken ?
really dont know how that happend
Best time depends on your calculations/goals. I’m not following your post too well, are you trying to make a ravencoin flight sheet? If so, which part are you stuck on?
Funds are tied to the wallet address they are mined to. If you have a pending balance on the eth hiveon pool you can manually request payout up to 20 days after the merge.
OK i have made it now thanks
rvn flightsheet with new wallet
just need to swap flightsheets
and adjust gpu if needed
is it poss to stop 1 fsheet and try now one and then revert ?
sorry for confusion will revert to first login hashroken
Hmm rvn not working when i switch but using same oc settings
Need to tune from scratch as the two algos are very different.
You can switch back and forth between flight sheets no problem
read read and read forum get all i can out of it but settings i cant seem to sus out
tried loads of different settings but no luck
You have ethash selected as the algo. Ravencoin is on kawpow
Ahh ok
im getting totally dif coins etc nothing like algo kawpow
unable to alter to kawpow
not sure what i have done
Lolminer doesn’t do kawpow
thats where i keep going wrong confused my self
RVN flight sheet
ethminer-kawpowminer
ETHASH
ok i got a bit futher
but still not running
Show your flight sheet
The whole thing
hope its what your after
my eth failed so i had to delete kawpow entry
and all working again
will have to try again tomorrow
Before clicking edit, what you showed before is fine just don’t top out your address
Couldnt sleep set it up again
here is both eth and rvn
not edited gpu fields yet
i cant see a problem
Can’t tell if you’re using a correctly formatted address or not since you’re censoring it, but what does the miner say in the console?
