Help Antminer L3++
In case, you see such an error when installing Hiveon ASIC firmware:
Anybody know an advice?
In Addition i got this error:
Socket connect failed: Connection refused
Maybe there is someone who can help ? :slight_smile:
Install HiveOS from an SD card.
Just run the Remove Signarutre tar file first, it will say exactly the same, then go back and flash HiveOS, it will flash Ok
Yes use the TAR file thats on the hiveos website in the installation guide. Read there and flash first. Just did it 5 minutes ago and it worked
Thanks for help, worked with sd card
How does the SD card option work? Can you explain me please :slight_smile:
