Help and Sugesstion
Hello famliy, Can a 2000-watt power supply be enough to power 12 of AMD RX 580 graphics cards?
there are many variables that come into play such as quality of psu, and what you are mining and what overclocks are set. most cheap 2000w i wouldn’t trust with half the power usage personally.
So you can’t suggest the best watt for 12 of Rx 580 right?
If i were building a 12 card today id use x2 1200w hp platinum server psus with breakout boards and a cheap atx psu for the motherboard
Thank you for the suggestion. I really Appreciate.
