Help! AMD 6800 won’t work on Hive OS
Good morning! I cannot get my Radeon 6800 to mine on Hive OS. Is there a way to get it to work? Settings? What version of Hive? Please help
Which miner are you trying to use? Are the AMD drivers loading?
Nanominer. No it doesn’t look like the drivers are loading … my other cards load fine but not the 6800. Any pics idea?
Ok, the reason I ask is I’m kind of having the same issue. Try nbminer, I got my 5600xt going with that one for a little but. If the drivers aren’t working you can try to update to a different Hive OS version. Either the newest version… if that don’t work try an older version. I got my drivers to recognize by doing that.
I’m still having issues to be continued, I just seen you weren’t getting any responses (same happened to me) so just trying to help, I’m still kind of a newbie but that’s what I’ve found so far.
Yea I’m going to try a new version and see how it goes.
I am succesfully using nbminer in a Rig with Radeon 6800 and 6800XT. Mining ETH+ZIL.
Buenas tardes, yo tengo un Minero con HiveOs, con 3 Placas RX580, una RX6700XT y una RX6800XT sin problemas.-
Estoy usando como minero teamredminer
“Radeon RX 6800 XT 16368 MB · MSI - Samsung GDDR6 · 113-V395TRIO-1OC”
La version de HIVEOS es: 0.6-205@210715
como maximo le saco: 61.26 MH, no cambie aun la BIOS por algo mejorado
