please help. why 1 card hahsrate drop in 3060ti card. afer reboot it will normal again. but after few hours hashrate will drop again, no announcement. im using the lattest t-rex/nvidia/hiveos. I really appreciate all information. thanks
if your driver is crashing (0% fan readout, so likely) you probably have too aggressive memory clocks. reduce and reboot until stable
thanks for reply
im trying oc many times, flash usb, update / downgrade nvidia/hive os, change rizer but not working.
only stable in this setting (0 0 135). before this card can run 44-45mh (1350 1850 145) for 4 months.
you have any idea what happen?
thanks
Leave the core where you had it before, that won’t be the issue, and running 0 core aka default is way more core than needed. if it’s unstable lower the memory clock alone, as that’s what your issue will be. The newer versions of lolminer don’t like as high memory on v1 Hynix 3060ti lhr. No need for power limit.
i use latest T-Rex. how i can get 44-45 mh? is i using 0 core,
thanks
0 core (default) is more than needed for eth. What miner/software/driver version are you running?
