Hashrate discrepency between HIveOS total and pool report
Morning,
Happy to have my hive rig up and running with a mix of 4 cards. 2 older Nvidia’s and 2 AMD (one new). Its my first rig and I am having fun now that I have it up and running.
What I am seeing is a combined hash rate on the rig much much higher than the pool its configured for.
I mean waaay different. I run the same minor on my laptop as a test - yes laptop is in windows so only the minor software is the same - ish (windows vs linus versions of wildrig). Laptop 1 hotrod card tracks directly to the pool being used on hashrate.
Is it the mix of cards throttling it back down from 50+ to 17mhz.
droppong pics on here of rig view, flight sheet and pool stats. Appreciate the help from more seasoned folks.
Coing in Zano - miner software Wildrig
New users on forums so it wouldnt let me post all at once.
Dashboard shot, showing the collective Hashrate.
average is what you want to pay attention to, also keep in mind miner dev fee. so youre pretty close to where you should be. looks like you had some kind of issue, whether network or rig crash, would have to enable logs and check them next time it happened
