GTX 1660 Super showing as TU116
Did you find a solution? I have the same MB and same problem…
its riser problem
unfortunately not, I had to replace motherboard and processor and now it is mining with all other peripherals and components, it is something related with the motherboard or the processor.
Vibe, thats suks… I did the same… Returned yesterday my motherboard… Thanks for replying
I have the same problem with a Biostar TB360 mother … I tried another mother (an Asus Z490-P) and it solved the problem. What motherboard are you using?
as I stated before it was a AsRock Z490 + PentiumGold
What Processor you got with that motherboard?
I got the same error with 1660 ti. GPU and Riser power cable was loose, I fixed it and problem solved
