GTX 1660 - not possible to set power limit
Hi, i have problem with my new GPU, it works but it is not possible to set power limit and GPUs are too overhot… is possible to fix it? Than you
i am ussinh this cards:
https://www.exasoft.cz/asus-ph-gtx1660-6g_d278868.html?gclid=CjwKCAjwx8iIBhBwEiwA2quaq-FxBySeS3JuQPx67icjjQBJd0UoJrQseRZVtfJGaP11H_XaeByJXRoC0SAQAvD_BwE
You use single fan GPUs. Single fan GPUs as addition has not the best radiator and as result they doesn’t cope with the task of heat dissipation
What you should to do?
Try use absolute core clock instead Core Clock Offset - put 1035 instead -200 and you will get around 70W power consumption and colder GPUs
