GTX 1060 6GB OC settings
Hynix mem can give less hashrate than micron/samsung
how to tweak 2 types of vga?? Thanks!
i have a ZOTAC GTX 1060 with 6GB micron memory, but i get only 15MH, what’s the problem?
Kernel: 5.4.0-hiveos #108
OS VERSION: 0.6-204@210608
DRIVERS: N 465.31
Here’s my clocks for 1660 with Hynix memory:
Do not downclock core, try +100 and look what happens
Hello brother I have question
after congig my NB config
memory tweak 1
platform 1
after that my amd is not mining how to run with both
please helo me
Merhaba Bendede Aynı Kart Var Ama Ben 17.5 MH Alıyorum.Sen Bios Attın mı?
Benım PL Degerlerı 90-120-180 eger Kullandıysan Paylaşırsan Sevinirim.
Zotac 1060 6 Gb Samsung Çip için Bios Paylaşabılırmısınız ?
Suan 17 Mh Verıyor 90w ile
Did you get invalids with this? Trying the mem tweak as well. How did you end up going with this
just to share my settings for 1060 6gb hynix (palit dual non-oc)
HiveOS t-rex: mt 1, +160 core, +1000 memory, PL 90
24hrs no invalid/reject on 2miner ETH pool. 22.77mh, 58c @ 32.5c ambient open air rig
this is the best so far i can get without temps going above 60c
Hello all, i have mined with nbminer with the memory tweak but i can’t confiq the file anymore. Someone know’s what happend?
Thankyou already
I mine on hiveos, with 1x gtx 1060 6GB and can get max 18,9 MH/s with oc, tried many settings, stock clock give 15-16 MH/s.
Miner: t-rex
algorithm: ethash on ethermine pool
hardware:
-mainboard - gigabyte ga-ep43-s3l
-cpu - Intel Duo E7400 @ 2.80GHz
-psu - modecom volcano 750
i am using asus 1060 6gb dual-oc (micron)
my settings are:
t-rex with “mt”: “2”
p0 state
100 core 600memory
PL 91
i get 23.35mh/s
Im getting 24.22 mh/z with settings 100/1450 pl 200
here is my setup for a GTX 1060 6GB GALAXY.
can get 24.2 with no crashes with 150/1400 and 125 pl probally best I can do because its micron memory
Im using nano miner because im dual mining monaro but my gtx 1060 gets 24 mh/s with 100c 1400 m and 125 power limit previous setting I posted I had a crash when the temp went down on gpu theses setting have been running 11 hour no crash
my https://tinyurl.com/3wa5mvh2 101power limit
Using NBMiner, driver 470.74
Using 1 day so far, seems stable. I tried with 300 CPU CLK but with that it crashed.
EDIT: [auto fan is enabled]
Thanks you!
